Date/Time: Fri, 29 Nov 2024 14:33:02 +0000
Linux
View Count: 501
[2023-01-31 05:42:57] |
User841161 - Posts: 221 |
Its looking like i may be transitioning to Linux as my main Operating system. Since Sierra does not operate straight on Linux, would you recommend running it on a windows virtual machine, or running it on linux while utilizing Wine.
[2023-01-31 11:04:10] |
emmanuel - Posts: 58 |
I run Sierra Chart using Wine, and others do as well. See Linux I've never tried it in a VM, but it should work. Although, in that case I recommend optimizing the disk IO so that Sierra Chart is able to write to its intra-day files with the lowest lag. I don't know about VirtualBox, but with libvirt you can install Windows with RedHat's VirtIO disk driver to avoid having to emulate a SCSI or IDE device. And if you use a dedicated partition or LVM logical volume for the virtual disk instead of a file, then that would reduce some overhead as well; Since using a file would cause disk IO to have to go through two filesystems. |
[2023-01-31 19:23:19] |
Emmanuel, Thanks a bunch for the info. |
