Date/Time: Fri, 29 Nov 2024 16:36:50 +0000
Line of liquidity following price on both side on NQ
View Count: 360
[2023-01-25 17:29:06] |
User160182 - Posts: 2 |
Hello, do you know why we have this line of liquidity following price on both side on NQ ? It's really disturbing. Can we clear it ?? Thx |
Screenshot_1.png / V - Attached On 2023-01-25 17:27:26 UTC - Size: 61.03 KB - 95 views Attachment Deleted. |
[2023-01-25 18:02:47] |
That looks like the Market Depth Historical Graph. Remove the study from your chart to get rid of it.
[2023-01-25 18:45:01] |
yes this is the Market Depth Historical and it's a chart for it, i'm talking about the liquidity who's not suppose to be here (line arround the price)
[2023-01-25 21:48:03] |
Which line are you referring to? We question the "shadow" like lines that are above and below where the price went through. Is that what you are referring to, or is it something else. If it is the above, then we would need to see your chart to see if we can reproduce it and then see what you have setup that is causing it. Follow these instructions to get us the chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
