Date/Time: Fri, 29 Nov 2024 16:49:54 +0000
Interest in Sierra Chart
View Count: 296
[2023-01-24 15:15:14]
Hmongtrader - Posts: 1
I am interested in Sierra Chart. I downloaded the software but when I tried to load a chart, it just blank. May I please get some help. Thanks.
Leo
[2023-01-24 17:38:26]
John - SC Support - Posts: 36350
Most likely the issue is that you were on a Standard Trial, which has limited symbols that you can use. We have set you on an "Activated Trial", which gives you access to all symbols.
Try closing the chart and reopening it and see if you get data.
Also, refer to the instructions at the following link for how to open a chart:
Getting Started, Opening Charts and Basic Trading: Open A Chart
