Date/Time: Fri, 29 Nov 2024 16:46:19 +0000
Number bar text
View Count: 291
[2023-01-23 19:30:59] |
Shawn Washington - Posts: 10 |
I saw someone with a number bar chart and the text was black if it was a light colored bar and black if it was dark. I have it set like this (based on slope) in my Number Bar Calculated Values portion but can't find how to do it for the number bars themselves. Please let me know how to do this-it would make it more visible and easy to read.
[2023-01-23 23:26:23] |
The only way to adjust the colors of the Numbers Bars is to use the Text Coloring Method and then enable the Use Separate Colors for Text Coloring Method and set the colors as needed. Refer to the following: Numbers Bars: Column # Text Coloring Method Numbers Bars: Use Separate Colors for Text Coloring Method For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
