Date/Time: Fri, 29 Nov 2024 16:51:45 +0000
[User Discussion] - From Windows 10 Pro 64 bit to Windows 11
View Count: 307
[2023-01-23 18:12:30]
User467494 - Posts: 21
Hi there:
I have to replace my computers as they are 8 years old. I'm now running SC on Windows 10 Pro 64 bit.
If I were to copy and paste the existing SC directory (under Windows 10 Pro 64 bit) to a new computer running Windows 11, would it be as simple as pasting to another computer running Windows 10 Pro 64 bit? I'd of course first install SC on the new computer.
Many thanks.
[2023-01-23 20:30:05]
ForgivingComputers.com - Posts: 960
Assuming you keep the same directory structure: Yes. There is no need to install it on the new PC first.
Date Time Of Last Edit: 2023-01-23 20:31:28
