Date/Time: Fri, 29 Nov 2024 16:31:40 +0000
Symbol(s) Missing in NASDAQ Total View
View Count: 390
[2023-01-22 17:50:13] |
SavantTrader - Posts: 110 |
Dear Support: I was reading an older thread [1], and noticed that at least one symbol/CUSIP is missing from the NASDAQ Total View selector. I am still able to type the symbol into my chart and use it - even though it does not appear in SEARCH or list selector. Please see attached example for GOOGL. I do not know if there are other missing search/selector references. [1] Older thread Delayed NASDAQ stock data - showing errors / Data upto July 2021 Date Time Of Last Edit: 2023-01-22 18:20:07
Capture4.png / V - Attached On 2023-01-22 17:49:54 UTC - Size: 138.8 KB - 92 views |
[2023-01-23 18:49:49] |
There are many symbols that are not listed in the Find Symbol list for the NASDAQ TotalView. We only populated about 100 of the most popular stocks. You have to type in the symbol name for any others that are not showing up.
