Date/Time: Fri, 29 Nov 2024 16:40:15 +0000
How to get pre market volume profile onto RTH only session chart?
View Count: 590
[2023-01-22 11:55:01] |
TopGunTrader - Posts: 172 |
Hi, I want to trade off a RTH only chart however also want to see the ETH pre market volume profile. I created another chart with full time and put a volume profile from 18:00 to 9:29:59 and then used Study/Price Overlay to put that on my RTH 9:30 to 16:15:00 chart and it didn't work. I'm sure there has to be a way to do this but I can't figure it out. There are many levels from previous day I want to see the overnight price action to me is good enough in the overnight volume profile. |
Capture.PNG / V - Attached On 2023-01-22 11:54:25 UTC - Size: 211.55 KB - 126 views |
[2023-01-22 11:56:28] |
I marked up some yellow lines of areas that you can't see on full time chart which would have helped me take a trade Friday that I didn't recognize. Resistance once broken becomes support etc!
[2023-01-23 18:26:32] |
There is not a way to do this, as the Volume Profiles can not be overlaid to a different chart (the lines from the study can be overlaid, but not the profile itself). Therefore, in order to see the ETH volume profile on a chart, the chart must include the ETH data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-23 18:26:43
[2023-01-24 11:37:30] |
Thank you for response was wasting too much time on this. I found a workaround that might help others. There's far less trading activity in the overnight session so volume/tick or what I'm using 250 delta bars cuts 90% down on overnight bars letting you see both previous days price action and overnight highs/lows and volume profile! I hope this helps others. |
Capture.PNG / V - Attached On 2023-01-24 11:35:29 UTC - Size: 313.2 KB - 96 views |
