Date/Time: Fri, 29 Nov 2024 16:43:47 +0000
Change date formatting in Time Scale area
View Count: 457
[2023-01-21 17:09:49] |
user_xyz - Posts: 416 |
I can't find where to change the formatting of the date in the lower left of a chart in the time scale area? Currently reads 3-1-20. Looks like you are just using XXX3 of the year for display here... See attached Date Time Of Last Edit: 2023-01-21 17:29:23
[2023-01-23 16:54:15] |
Actually, it is just cut off at the edge of the chart. If you were to scroll to January 1, 2023 you would see that it is trying to display as 2023-1-20. But in order to fit it into the edge and not overwrite other data, you can only see the last number of the year. There is not a way to change this format. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
