Date/Time: Fri, 29 Nov 2024 16:35:29 +0000
No estimated Que position when replaying chart
View Count: 309
[2023-01-20 23:28:08] |
opmetal - Posts: 70 |
I just enabled CME market depth data and have reloaded chart data but am not getting estimated Que position during a replay (always shows EP:1). Live data does show full market depth in the DOM.
[2023-01-23 15:30:13] |
When you are performing the replay are you getting the Market Depth data showing up, or do you just have 1 level of depth? If you just have 1 level, then you need to record the market depth data in order to have it available during a replay. Refer to the information at the following link: Replaying Charts: Replaying of Market Depth Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-23 16:28:02] |
I get replay market depth only starting on 1/23/23 (today). Shouldn't I be getting historical market depth from Denali?
[2023-01-23 22:40:45] |
You will only have historical market depth if you have set the system to record it, or if you have the Market Depth Historical Graph on a chart for a symbol. Refer to the following: Market Depth Historical Graph: Step by Step Instructions To download historical Market Depth data, then be sure you have gone through the instructions for this at the following link: Market Depth Historical Graph: Downloading Of Historical Market Depth Data Even if you setup the downloading of the Historical Market Depth Data, you still should set the symbol to record the market depth so that the data is recorded (stored) while you are connected to the data service, instead of having to wait for it to download later. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
