Date/Time: Fri, 29 Nov 2024 18:48:04 +0000
HIGH/LOW for time period -extended always visible
View Count: 371
[2023-01-20 07:32:19] |
User901414 - Posts: 5 |
Hello, I use HIGH/LOW for time period -extended and it works perfect but the lines are always visible on my chart. So, till, we arrive at the end of the "extend limit", the automatic range gives a bad look on my chart How can I do ? Best regards |
[2023-01-20 15:18:44] |
Sorry, but we are not understanding what exactly you want to do. If you want the lines to not extend very far, then you would need to set the time for the extension to be right after the end of the time period. If it is something else, then we need more information on what you are wanting to ask. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-21 06:18:27] |
Hello In fact, line extensions are still showing on the charts. If they are very far from the current price, they generate a very large zoom out on the chart (with scale range automatic). I don't have this problem with other "classic" lines : They are displayed on the chart if the price is close, but they are no longer displayed (but they still exist) if the price is far. Is there a way for these lines to be well extended but not necessarily focused (= not necessarily displayed on the chart if the price is far away with scale range automatic)? Best Regards |
[2023-01-23 16:35:58] |
Refer to the following: Chart Studies: Preventing Study From Compressing Main Price Graph For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
