Date/Time: Fri, 29 Nov 2024 19:38:08 +0000
Recommended font to ensure I can see the bar spacing icons on the tool bar
View Count: 289
[2023-01-16 18:37:07] |
KM13770 - Posts: 1 |
Can you tell me the recommended font to ensure I can see the bar spacing icons on the tool bar. I am seeing >|< >>|
[2023-01-16 20:44:26] |
We could not possibly tell you what font is best, as it depends on personal factors. You would need to play with the Control Bar Text Font to determine what works best for you. Refer to the following: Graphics Settings: Control Bar Text - (current font name) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
