Date/Time: Fri, 29 Nov 2024 19:26:14 +0000
AMP y rithmic
View Count: 298
[2023-01-16 15:55:45] |
User470718 - Posts: 3 |
Hola Tengo una cuenta live con AMP y data de rithmic. Opero solamente ES y NQ Me gustaria usar sierra chart En amp pago por los datos USD$12 y por rithmic USD$25 Me podrian decir que paquete debo pagar para usar sierra chart para operar solamente ES y NQ usando el TPO Muchas gracias |
[2023-01-16 18:45:52] |
From Google Translate: I have a live account with AMP and dating from rithmic. I operate only ES and NQ
I would like to use sierra chart In amp I pay USD$12 for data and USD$25 for rithmic Could you tell me what package I have to pay to use sierra chart to operate only ES and NQ using the TPO Since you are wanting to connect to your AMP account, you will need to be on one of the Integrated Packages. Since you state that you want to use TPOs, then you would need to be on either the Integrated Advanced or Integrated Advanced with MBO - depending on whether you want MBO (Market by Order) information or not. You will find the information on these packages and their cost at the following link: Description of Service Packages and Pricing: Integrated Packages We highly recommend using our Denali Exchange Data Feed for your data. Refer to the information at the following link: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
