Date/Time: Fri, 29 Nov 2024 19:44:13 +0000
Doubt settig up indicator
View Count: 294
[2023-01-16 09:10:36]
OriolCasas - Posts: 166
I am setting up the indicator with the setting you cn see attached.
On picture 2, when I want to change the draw style, from "line" to let's say "transparent text" and click apply, somehow it automatically moves back to "line". What can be the reason for this?
Thank you
image50MA Sierra.png / V - Attached On 2023-01-16 09:08:31 UTC - Size: 122.64 KB - 85 views
image50MA 2.png / V - Attached On 2023-01-16 09:08:35 UTC - Size: 45.14 KB - 71 views
[2023-01-16 17:18:22]
John - SC Support - Posts: 36350
You are using a Study/Price Overlay. For this study there are controls on the Inputs for what can be changed within the overlay study as opposed to using the information directly from the source study.
In this case in particular, to change the Draw Style, you first need to change the Input for Use Styles and Widths from Source Study to No and select Apply. Then you will be able to change the Draw Style. Refer to the information here:
Study/Price Overlay Study: Use Styles and Widths from Source Study
