Date/Time: Fri, 29 Nov 2024 19:26:08 +0000
chase order ticks input variable
View Count: 302
[2023-01-16 08:36:50]
User368741 - Posts: 17
can the ticks input for trailing in chase order be variable like the value of ATR for an instance
[2023-01-16 17:14:49]
John - SC Support - Posts: 36350
No, you can not have the amount of the trail be variable for the Trailing Order types.
But, you can use the Trade Management by Study to do this. Refer to the information here:
Attached Orders: Study Controlled Targets and Stops
