Date/Time: Fri, 29 Nov 2024 20:57:27 +0000
ouverture chartbook
View Count: 281
[2023-01-13 17:01:57]
User220939 - Posts: 36
Bonjour,
je voudrais créer un bouton dans la control bar pour charger directement un de mes chartbook sans passer par "opencbook".
Merci
[2023-01-13 18:49:23]
John - SC Support - Posts: 36350
From Google Translate:
I would like to create a button in the control bar to directly load one of my chartbooks without going through "opencbook".
We do not have a built-in way to do this.
The only option would be to create a custom study to do this. Refer to the following:
Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events
