Date/Time: Fri, 29 Nov 2024 21:01:37 +0000
NYSE TICK no data
View Count: 318
[2023-01-13 14:51:12] |
User984730 - Posts: 7 |
Hello, i have issues with NYSE TICK chart : all candles are flat even tho we are in cash session. Other data like price and volume works fine |
Attachment Deleted. Capture d’écran 2023-01-13 à 15.50.11.png / V - Attached On 2023-01-13 14:50:26 UTC - Size: 82.87 KB - 75 views |
[2023-01-13 18:35:36] |
That does not look like the TICK-NYSE from our Market Statistics. The following link is an image of what we see from our TICK-NYSE: https://www.sierrachart.com/image.php?Image=1673634848219.png You would have to check with whomever is providing that data as to why you are getting what you are. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
