Date/Time: Fri, 29 Nov 2024 20:57:50 +0000
Controls constant freezing, having to disconnect and reconnect.
View Count: 300
[2023-01-12 19:55:21] |
User654138 - Posts: 27 |
Hi, My chart controls and buttons keep freezing, I have to disconnect and reconnect to get them to function again. I have had to this probably 20 times yesterday and today. I tried downloading the program again but same result. I have never had this happen before. I need to correct this, any ideas? Thanks |
[2023-01-12 21:39:08] |
Please get us a copy of your Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-13 03:04:36] |
I just used the send for analysis button to forward it
[2023-01-13 14:12:15] |
Sierra_Chart Engineering - Posts: 17243 |
When you say freezing, is the user interface of Sierra Chart inoperable and in a frozen state? Or is it that charts are not updating?
