Date/Time: Fri, 29 Nov 2024 21:00:40 +0000
vwap daily
View Count: 319
[2023-01-12 07:52:09]
User220939 - Posts: 36
Bonjour,
J'ai 2 graphiques en daily dax, et je n'ai pas les mêmes niveaux du vwap yearly, alors qu'ils sont réglés pareil.
sur un graph j'ai vwap a 14537,et sur l'autre j'ai vwap a 14610
Je n'arrive pas à comprendre d'ou vient cette différence, et quelle est la bonne valeur.
Merci
[2023-01-12 15:50:10]
John - SC Support - Posts: 36350
From Google Translate:
I have 2 charts in daily dax, and I don't have the same vwap yearly levels, although they are set the same.
on one graph I have vwap at 14537, and on the other I have vwap at 14610
I can't understand where this difference comes from, and what is the correct value.
The obvious items are to ensure that the VWAP settings are the same between the charts. And then you also need to ensure that the Chart settings that might affect the underlying data are the same - such as New Bar at Session Start and the Session times, etc.
