Date/Time: Fri, 29 Nov 2024 20:55:10 +0000
chart dom numbers are squished together
View Count: 438
[2023-01-12 07:31:25] |
akx814 - Posts: 3 |
is there a way to make my chart dom readable?
squished chart dom.PNG / V - Attached On 2023-01-12 07:30:55 UTC - Size: 45 KB - 92 views |
[2023-01-12 14:30:15] |
ondafringe - Posts: 286 |
How do I make DOM font larger?
[2023-01-12 17:11:05] |
Refer to the following setting: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
