Date/Time: Fri, 29 Nov 2024 21:01:31 +0000
[User Discussion] - Multiple keyboards for shortcuts?
View Count: 401
[2023-01-11 15:26:52] |
knarf01 - Posts: 48 |
Good morning support. I currently run a few keyboard shortcuts for trading. I would like to get a secondary pad for this function. Instead of an actual macros keypad I was thinking of using a secondary keyboard. Before I order one I was wondering if using a second keyboard would conflict with my main keyboard or would Sierra be able to designate a certain keyboard commands as the shortcut? The idea is not accidentally kick off trades from my main keyboard. Any suggestions are appreciated. |
[2023-01-11 17:40:35] |
ondafringe - Posts: 286 |
From what I understand, a secondary keyboard works the same as the primary keyboard. A key press on either keyboard will generate the same ASCII key code and the same Windows key code, you are just using one keyboard versus the other based on preference/convenience. That said, I haven't used a secondary keyboard, so take it with a grain of salt. :)
Date Time Of Last Edit: 2023-01-11 21:35:40
