Date/Time: Fri, 29 Nov 2024 21:55:41 +0000
[Programming Help] - Event for study settings update
View Count: 305
[2023-01-10 04:07:19]
User907967 - Posts: 54
Hi, I'm using several SCSubgraphs which load based on SCInputRef settings. When I change the settings for any relevant SCInputs and press "apply", the subgraphs regenerate correctly using the new SCInputRef values. The new subgraph representations are correct, but I see that the old representations don't disappear. Imagine generating circles using SCInputRef settings for the diameter. As I load the study, if the input is X, the relevant circle will have a diameter of X. When I edit the study to change the input from X to X*2, once I press "apply", another circle appears of X*2 diameter.
How can I get rid of the old subgraph representation?
Thank you.
[2023-01-10 04:31:25]
I found this event: is.IsFullRecalculation
I am using this event to reset my Subgraphs, and then new settings kick in.
All sorted.
