Date/Time: Fri, 29 Nov 2024 21:01:31 +0000
Need Help with Flex Renko
View Count: 617
[2023-01-08 22:31:25]
User810342 - Posts: 4
Hello, I'm having some challenges with the new Renko futures. I'm trying to reproduce the same image attached (It was created using the 5Min chart and the Study Renko Chart (unsupported) set to 10-ticks. Is it not possible to use Renko with timebased charts like daily, Hourly and minutes? Or is there a way to configure the new Renko Flex to produce the same result?
I would greatly appreciate your help with this.
Aime
imageRenko Screenshoot.png / V - Attached On 2023-01-08 22:29:56 UTC - Size: 31.73 KB - 136 views
[2023-01-09 16:39:10]
John - SC Support - Posts: 36350
In your image it shows a "Box Size" of 4, so most likely this would be a standard Renko with a setting of 4.
Refer to the information for Renko charts at the following link:
Renko Bar Charts
[2023-01-11 03:39:40]
Actually my question is more about if it's still possible to do renko based on 30 minutes for instance.
[2023-01-11 16:07:37]
Sierra_Chart Engineering - Posts: 17244
No it is not possible.
Date Time Of Last Edit: 2023-01-11 16:07:47
