Date/Time: Fri, 29 Nov 2024 21:37:30 +0000
Candle Close Opne Difference
View Count: 373
[2023-01-08 03:51:05]
User886069 - Posts: 17
I'm having a problem with matching Candle close and open price on 4h(ES/NQ/CL) with my other platform=TOS. 30m and 1h is just fine and daily has a little difference - but 4h chart in particular showing different prices. Could you help with this?
image2023-01-08_12-49-03.png / V - Attached On 2023-01-08 03:50:10 UTC - Size: 52.59 KB - 86 views
image4h chart.png / V - Attached On 2023-01-08 03:50:18 UTC - Size: 157.19 KB - 83 views
[2023-01-08 11:09:10]
Sierra_Chart Engineering - Posts: 17247
Usually this will relate to the starting time of the chart bars. Refer to:
Chart Session Times: Bar Starting Times
