Date/Time: Fri, 29 Nov 2024 12:44:46 +0000
How do i connect my tradovate account with sierra chart?
View Count: 2484
[2023-01-06 01:40:56] |
Sivle - Posts: 53 |
I wonder how to connect tradovate account with sierrachart ? I have also bought "market data" to be able to see the depth or the data in the DOM, for example. I am now wondering how to link my tradovate account with sierrachart? Because at this moment i have a funded tradovate account with "market data" from tradovate. And I wonder if market data/data feed is the same thing? in that case, I have already bought "market data" to see the depth and all the information for the MES futures contract. Does this then mean that I don't need to buy market data/data feed from sierra chart because I already bought "market data" from tradovate? I plan to use DOM, footprint, volumeprofile/marketprofile and vwap in sierra chart and wonder if my market data from tradovate will work? please help |
[2023-01-06 05:05:09] |
Sierra_Chart Engineering - Posts: 17226 |
First, we have activated your Sierra Chart account for two weeks. tradovate uses CQG, so you need to connect to that trading service with CQG: CQG Trading Platform Service You must use our Denali Data Feed for data and pay exchange fees to access the market data in Sierra Chart: Denali Exchange Data Feed You are going to need Service Package 11 for the particular functionality that you need in Sierra Chart: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-06 05:05:59
[2023-01-08 04:21:50] |
Sivle - Posts: 53 |
Hi i heard from my broker wich is tradovate that they sont support sierra chart anymore is that true? here is the message: "Hello, Unfortunately, we have made a business decision not to set up connectivity for customer accounts with Sierra. All previous users with this set up are grandfathered but we are not setting these up anymore. There are other 3rd party platforms we can still connect through CQG like InvestorRT, Motivewave, etc. but we are no longer supporting this for Sierra users." is this true? Date Time Of Last Edit: 2023-01-08 04:25:41
[2023-01-09 07:04:05] |
Excellent! We are very very happy with this decision. Makes it much much easier for us. And why is it "unfortunate". Should they not say fortunate? If they made this decision, then obviously they agree with it and therefore it must be good for them. Therefore to do this: I plan to use DOM, footprint, volumeprofile/marketprofile and vwap in sierra chart
You will need Service Package 11 and activate the exchanges you need for real-time data.:Description of Service Packages and Pricing Activation of exchanges is done here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed To authorize the real time CME data, refer to: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-09 07:04:57
[2023-01-09 22:57:00] |
Sivle - Posts: 53 |
Does AMP futures broker work with sierra chart.
[2023-01-09 23:03:17] |
Sivle - Posts: 53 |
Does sierra chart work with AMP Futures and Teton routing service and denali feed?
[2023-01-10 15:02:46] |
Sierra Chart works with AMP futures by using CQG for the order routing. AMP does not have support for the Teton Order Routing Service. You have to use the Denali Exchange Data Feed when using CQG for order routing, as we do not support data from CQG for the CME Group and EUREX. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-10 16:24:35] |
Sivle - Posts: 53 |
is it good to use AMP futures? tradovate is also using CQG. Whats the difference between tradovate and AMP. wich data feed do users use if they have teton order routing service? |
[2023-01-10 17:27:46] |
AMP is fine. Tradovate, as discussed above, has specifically stopped setting up CQG for Sierra Chart accounts. Therefore, it is there choice to no longer support Sierra Chart. This is completely separate from CQG. As to the differences between Tradovate and AMP, you would need to look into the differences in their costs and then talk to others about their experiences with each. With either CQG or Teton you HAVE to use the Denali Exchange Data Feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-11 16:26:58] |
Sivle - Posts: 53 |
is there some disadvantage to use CQG for order routing and Denali Exchange data feed? i have heard bad things about CQG but i dont know exactly what the issue is. I would appreciate if somebody could give me an explanation. |
[2023-02-06 16:42:04] |
No, there is no disadvantage with using CQG and the Denali Data Feed. We will have someone follow up with you.
[2023-02-06 17:02:51] |
SC Support - Posts: 1895 |
Spoke to Silve, talked about set-up
Date Time Of Last Edit: 2023-02-06 17:03:25
