Date/Time: Fri, 29 Nov 2024 22:38:36 +0000
delete drawing - Anchored VWAP "ECIVwapAnchorV1.5" (not hide)
View Count: 354
[2023-01-06 00:44:09]
mbarbhaya - Posts: 37
Dear Support,
Please help me with one issue with Anchored VWAP "ECIVwapAnchorV1.5"
After I draw anchored VWAP on my chart and then when I want to delete that drawing, I don't find that option.
The only option I see is to either hide that study of to remove that study. Please let me know if their is any alternate way to knock-it off when not needed.
Thank you
Manish
[2023-01-06 15:14:21]
John - SC Support - Posts: 36350
The ECIVwapAnchorV1.5 is not one of our studies. It is included as a courtesy as part of our User Contributed Studies. As such, there is not much help we can provide, as we just are not familiar with the study.
But, from what you are stating, it sounds like what you are doing is correct. It sounds like the study is setup to allow you to draw initially in order to set an initial point, but then the study is not creating a drawing - it is creating a Subgraph array of the data. Therefore, you can not use the drawing tool options to remove/change the line. You would have to use the study related items - such as changing the Draw Style, or removing the study.
[2023-01-06 15:18:19]
Thank you John , I will reachout to the creator/developer of that Study Anchored VWAP "ECIVwapAnchorV1.5" -- Emmanuel Chriqui (aka wwwingman, contact : ecivwap@chriqui.name)
