Date/Time: Fri, 29 Nov 2024 22:46:43 +0000
[User Discussion] - Trial activation no sms received
View Count: 332
[2023-01-05 21:51:29]
User965620 - Posts: 5
File attached.
imageSchermafbeelding 2023-01-05 223849.jpg / V - Attached On 2023-01-05 21:50:46 UTC - Size: 45.63 KB - 72 views
[2023-01-05 23:37:51]
John - SC Support - Posts: 36350
We have activated the trial for your account.
[2023-01-06 13:46:09]
File attached
imageKnipsel.PNG / V - Attached On 2023-01-06 13:41:44 UTC - Size: 110.93 KB - 72 views
[2023-01-06 14:20:07]
If Sierra Chart is running, it will be activated within approximately 3 minutes. You will know it is active when "Global Settings >> Data/Trade Service Settings >> Service" is set to "SC Data-All Services" and you can connect to the data feed with "File >> Connect to Data Feed".
the information in your email can i not connect to the data feed with file
imageKnipsel.PNG / V - Attached On 2023-01-06 14:15:04 UTC - Size: 110.93 KB - 70 views
[2023-01-06 14:45:21]
Sierra_Chart Engineering - Posts: 17266
The symbols you are using are not correct. You need to translate them with this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
