Date/Time: Fri, 29 Nov 2024 22:35:28 +0000
Current Date - Time different from system Date - Time
View Count: 389
[2023-01-05 17:16:30]
GermanUser42 - Posts: 1
here in the Main Control panel i see the time: 16:41:45 +0000
In SierraChart the time under the candles is the same.
But my system time is 17:41:45 (the correct time here in germany).
I think the data feed is up to date(time), but i cannot find out where the settings are wrong.
Best regards
[2023-01-05 21:51:18]
ondafringe - Posts: 286
See if this helps:
Chart > Chart Settings > Session Times > Time Zones
Global Settings > General Settings > General > Periodically Set System Date/Time From Server
[2023-01-05 23:35:38]
John - SC Support - Posts: 36350
As noted above, it sounds like your chart is set to a time zone that is one hour prior to your actual time zone. The Global Time Zone is set in Global Settings >> Time Zone Settings. Your charts can be set to use the Global Time Zone, or they can use a different time zone (i.e. every chart can use a different time zone if you want). Therefore, you would also need to check your chart time zone (Chart >> Chart Settings >> Session Times >> Time Zone).
Refer to the following for more information:
Time Zone Setting
