Date/Time: Fri, 29 Nov 2024 22:34:42 +0000
Change
View Count: 283
[2023-01-05 11:47:06] |
the white rabbit - Posts: 22 |
Dear team, I am using the "text display for study from chart" study to display some information. However, I would like to know if it possible to change the color of the text display according the value. Example : If the number is positive then the text turns green. and if the number is negative then the number turns red. Thank you |
Screenshot (167).png / V - Attached On 2023-01-05 11:46:43 UTC - Size: 2.69 KB - 84 views |
[2023-01-05 18:46:26] |
You would have to modify the source code for the study to do this. Refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
