Date/Time: Fri, 29 Nov 2024 20:54:27 +0000
dom volume profile
View Count: 598
[2023-01-04 22:37:14]
Gtrader510 - Posts: 72
hello is there any way to use two volume profile on dom which one of them shows only us session and one shows from after market to us open since i live in california so it would be 6:30 to 14:59:59 1 profile and then 2nd should start at 15:00 to 06:29:59 which would be after market this profile should stop and fist profile should reset and start again. i have same profiles setting on chart but it wont let me do same thing on dom. please help
[2023-01-05 17:37:27]
John - SC Support - Posts: 36350
There is not a way to do this on the Trading DOM as the Volume by Price study is limited in the options available on the Trading DOM.
[2023-01-12 04:31:49]
Sierra_Chart Engineering - Posts: 17243
There might be some limitations with doing this on a Trading DOM. We would have to check.
