Date/Time: Fri, 29 Nov 2024 22:53:06 +0000
Teton Support
View Count: 305
[2023-01-04 19:00:42]
Angelfig - Posts: 2
is i think im still currently on CQG order routing, i assume im going to need to switch to Teton to get my data to work? if so how do i switch also is Teton supported by AMP Brokers?
[2023-01-04 20:40:27]
Sierra_Chart Engineering - Posts: 17266
No you do not have to switch to Teton order routing. We do recommend using Teton but you do not have to if you are using CQG. AMP does not support Teton order routing now.
What is the specific data issue that you have?
