Date/Time: Fri, 29 Nov 2024 22:44:34 +0000
Rename Tab pop-window window is not visible but takes over mouse focus
View Count: 359
[2023-01-03 21:25:29]
aviat72 - Posts: 36
I have a chartbook with a dozen plus tabs.
The charts are maximized and I switch tabs to see different charts.
All charts are in the main SC window.
The main SC window is maximized.
When I right click on a tab and select the rename option, I lose mouse control. The chart still updates.
I figured out that when you press rename there is a window which pops up where you can update the name.
However the window seems to get hidden when SC is in full-screen.
So the focus is stuck on the window where we rename the chart, but that window is not visible.
I had to kill the SC process a few times before I figured out what was happening; running the main window in the non-maximized mode is how I identified the focus issue.
[2023-01-04 05:45:58]
aviat72 - Posts: 36
Additional context:
The tab whose name I was trying to change was the rightmost, and the chartbook had more tabs than what could be visible (it had tab scroll arrows).
I do not face the issue when working with a Chartbook with three chart tabs.
[2023-01-04 20:26:04]
Sierra_Chart Engineering - Posts: 17266
We will check on this but we are not able to reproduce this even with the conditions described in post #2:
Date Time Of Last Edit: 2023-01-04 20:26:20
[2023-01-06 01:38:51]
aviat72 - Posts: 36
I have a workaround so it is not very urgent.
It was just that it was a weird situation to see the charts updating, the mouse moving but not knowing what to do since the window was not visible.
