Date/Time: Fri, 29 Nov 2024 22:54:13 +0000
DOM candle color + wick color?
View Count: 521
[2023-01-03 21:02:25] |
TopGunTrader - Posts: 172 |
Hi, I spend so much time this afternoon trying to find setting to change DOM candle color and can't find it. I searched support board for DOM candle color and couldn't find the answer. I watched DOM vs chart with DOM on it and I see why most people I follow use real DOM vs the chart DOM, just need to be able to see wicks and change candle colors. |
Capture.PNG / V - Attached On 2023-01-03 21:02:14 UTC - Size: 122.36 KB - 88 views |
[2023-01-04 18:37:52] |
Sierra_Chart Engineering - Posts: 17266 |
This is controlled through the Candlestick colors set through Graphics Settings: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-04 20:47:35] |
I saw those settings on CHART DOM but the regular DOM doesn't seem to have them I don't believe. I can't find it at least. Looked for 20-30 mins.
[2023-01-05 17:01:28] |
In general, a Trading DOM does not display the bars. If you have bars displayed in the Trading DOM, then you must have used the Study/Price Overlay to get the information to display. In which case, depending on your settings for the Study/Price Overlay, the colors are either set by the Graphics Settings (as noted above) or through the Study/Price Overlay Subgraph settings.
