Date/Time: Fri, 29 Nov 2024 20:59:26 +0000
rolling 20 and 5 day Volume Point of Control
View Count: 426
[2023-01-03 16:27:21] |
coachted - Posts: 329 |
What is the best way to get a rolling 20 day volume point of control for the full trading session for the s&p futures?
[2023-01-04 22:31:02] |
Refer to the following: Volume Value Area Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-05 01:23:43] |
Sierra_Chart Engineering - Posts: 17244 |
Since you want rolling, you would need to use the Volume by Price study for this. We will prepare instructions on how to do this. Also you would only have an accurate value POC value at the end of the chart. Not historically.
[2023-01-12 04:29:53] |
Refer to the settings here for the Volume by Price study for what you would want: Volume By Price Study: 20 Day Point of Control at End of Chart Based on 24 Hour Session Here is information for the Volume by Price study : Volume By Price Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-12 04:30:29
[2023-01-13 18:41:21] |
so why would the volume valueas point of control not be the same value if the time length is set to 20 days?
[2023-01-13 19:15:10] |
We are not understanding the question. And these kinds of questions are impossible for us to answer. We do not know what you are doing, we do not have your charts or Chartbook or data.
