Date/Time: Fri, 29 Nov 2024 22:43:31 +0000
Make Dom font larger.
View Count: 360
[2022-12-22 01:13:54]
User296581 - Posts: 10
I have gone to fonts on graphic settings and tried to enlarge DOM font from 8 to 12.
This should be simple, but nothing happens. have used Sierra Charts for 10 years, and the DOM for 1 year. Just need a simple answer. I have tried the search for "make DOM font larger" and variation of same query to the support board. Please help me.
[2022-12-22 11:33:17]
User282741 - Posts: 36
What do you mean enlarge DOM font?
If you mean DOM quantities /sizes and size in which prices are displayed do the following:
left click on your DOM and then:
Chart -> Graphics Settings -> Fonts tab and adjust Chart Text and DOM Quantities / Sizes settings
[2023-01-04 20:30:08]
Sierra_Chart Engineering - Posts: 17266
Make sure you are adjusting the correct Font. They are all listed here:
Graphics Settings: Fonts and Text Appearance
And make sure you are opening the correct Graphics Settings window. There is one global and one for the chart:
Graphics Settings
