Date/Time: Fri, 29 Nov 2024 23:50:13 +0000
[User Discussion] - How do I make DOM font larger?
View Count: 417
[2022-12-21 21:14:15]
User296581 - Posts: 10
I have gone to fonts on graphic settings and tried to enlarge DOM font from 8 to 12.
This should be simple, but nothing happens. have used Sierra Charts for 10 years, and the DOM for 1 year. Just need a simple answer. I have tried the search for "make DOM font larger" and variation of same query to the support board. Please help me.
[2022-12-21 21:15:09]
[2022-12-23 01:43:03]
ondafringe - Posts: 286
If you're talking about the price ladder font size, you can right-click on the price ladder, left-click Scale Settings, then play around with those settings.
If you choose Constant Range, the smaller the number you use for Range, the larger the font size.
Constant Range Scale Mode allows you to set how often the price ladder recenters.
Some of those other setting may affect font size, as well, but I only use what I pointed out, above.
