Date/Time: Fri, 29 Nov 2024 20:52:57 +0000
active free trail
View Count: 434
[2022-12-04 15:33:54] |
MeandMe - Posts: 6 |
Hi, please active free trial, I tried from Global settings---> Active Trial but it gives error.
[2022-12-05 16:23:06] |
We see that your trial is now active.
[2023-01-04 18:14:28] |
imran - Posts: 1 |
Hi please activate my free trail my sms code did not work i guess
[2023-01-04 20:56:21] |
Sierra_Chart Engineering - Posts: 17243 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-09 11:59:51] |
User426043 - Posts: 1 |
Hello, I wanted to activate my trial account and I put my phone number in but I didn't get any code. Can you help please. |
[2023-01-09 17:17:34] |
User426043: We have activated the trial for your account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-12 11:49:22] |
rydthewave23 - Posts: 1 |
hello support please activate free trial ,the sms tx message flagging up error message. failed to send code to number, sms already sent to number ,no sms arrived so no code! |
[2023-01-12 16:08:53] |
rydthewave23: We have activated the trial for your account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-12 22:51:31] |
0xSnervo - Posts: 1 |
[2023-01-13 15:15:28] |
0xSnervo: We have activated the trial for your account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
