Date/Time: Sat, 30 Nov 2024 12:28:30 +0000
Using all or a second core/ CPU for Sierrachart
View Count: 657
[2022-11-21 18:46:25] |
Jia T P R - Posts: 26 |
Hi i couldnt find it in the Forum , how to let SierraChart use a second CPU or all of them? kind Regards |
[2022-11-22 15:40:32] |
There are some built-in capabilities for using multiple cores, mostly in terms of the data stream versus the main program. But the best way to take advantage of multiple CPUs is to use multiple instances (sub-instances in particular). Refer to the following: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.47 - Use Sub Instances to Distribute Processing Load Also refer to the following: Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
