Date/Time: Sat, 30 Nov 2024 12:28:04 +0000
gap and no courses didnt fixed
View Count: 269
[2022-11-21 06:49:36] |
User562957 - Posts: 58 |
Hello support team, my fesx chart have no courses from the 14th november 7:40 pm to 15th november 5:35 a.m you can see it in the picture. 9h no courses...What can I you do to fix it ? |
problem.png / V - Attached On 2022-11-21 06:48:31 UTC - Size: 18.17 KB - 82 views |
[2022-11-21 18:17:07] |
Refer to the following: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
