Date/Time: Sat, 30 Nov 2024 12:38:16 +0000
Remove Buy/Sell Order Column on Chart DOM
View Count: 1443
[2022-11-19 18:09:34]
User440951 - Posts: 50
I want to remove the "Buy/Sell order Column" columns to keep only the "Combined Bid/Ask Size" when the "Trading chart DOM on" is activated.
I can't delete them with the arrow like you can with the other "Hidden Columns".
The result I'm looking for is the one in the attached capture.
Thank you in advance for your help.
imageCapture Combined BidAsk.PNG / V - Attached On 2022-11-19 18:08:56 UTC - Size: 43.35 KB - 157 views
[2022-11-21 17:36:33]
John - SC Support - Posts: 36350
The Buy/Sell columns are special. On a Trading DOM these columns will always be displayed. You can replace the Buy/Sell with "Bid Size/Buy" and "Ask Size/Sell", but you still have the Buy/Sell columns. Therefore, you can add the "Combined Bid/Ask Size" column, but you will not be able to remove the Buy/Sell columns.
You can move them to the right or the left. Refer to the following:
Global Trade Settings Windows: Move Up/Left (Trade >> Customize Chart/Trade DOM Columns)
Note that on a Chart DOM, you do have an option to turn off "Chart Trade Mode On" and enable "Show Market Data Columns". In this case, you could get what you are wanting, but then you can not place trades from the chart (since it is not in trade mode). Refer to the following:
Trade Menu: Show Market Data Columns (Trade menu)
[2022-11-21 19:31:51]
It's perfect, it's exactly what I wanted !
