Date/Time: Sat, 30 Nov 2024 12:45:29 +0000
CHARTBOOK FILE IS NOT COMPATIBLE - NEED SC SUPPORT TO HELP CONVERT IT
View Count: 344
[2022-11-19 13:17:33] |
User509345 - Posts: 44 |
Hello, Can you help converting these 2 old chartbooks that worked with older version but do not work with the latest one? (See the attached files) Best |
JT-FootprintTemplate.Cht - Attached On 2022-11-19 13:16:49 UTC - Size: 49.26 KB - 120 views JT-TICK-NYSE.Cht - Attached On 2022-11-19 13:17:05 UTC - Size: 67.68 KB - 280 views JT-Volume-Delta.Cht - Attached On 2022-11-19 13:17:12 UTC - Size: 47.67 KB - 151 views |
[2022-11-21 17:24:39] |
Attached are the updated chartbooks.
Attachment Deleted. JT-FootprintTemplate.Cht - Attached On 2022-11-21 17:24:18 UTC - Size: 4.46 KB - 254 views JT-TICK-NYSE.Cht - Attached On 2022-11-21 17:24:27 UTC - Size: 4.41 KB - 234 views JT-Volume-Delta.Cht - Attached On 2022-11-21 17:24:35 UTC - Size: 4.15 KB - 192 views |
