Date/Time: Sat, 30 Nov 2024 12:49:11 +0000
Drawings after Rollover
View Count: 686
[2022-11-19 12:34:21]
User962044 - Posts: 6
Hello. Please is there a way i can copy all my drawings between different symbols? For example I trade WTI OIL and after Rollover to fresher contract my drawings disapear. Thank you.Mark
[2022-11-21 16:43:43]
John - SC Support - Posts: 36350
The first thing to keep in mind is that when you rollover the symbol there is an option for Also Rollover Chart Drawings. You will want to have this enabled so the drawings will change symbols as well.
Changing to a New Futures Contract Month: Changing to a New Futures Contract Month
After the fact, you can do one of two things:
- Select Chart >> Update Chart Drawings to Current Symbol: Refer to the following:
Chart Menu: Update Chart Drawings to Current Symbol (Chart menu)
- Enable the option for Chart >> Chart Settings >> Chart Drawings >> Show Chart Drawings for Different Symbols: Refer to the following
Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu)
[2022-11-21 17:13:26]
It works. Thank you very much.
