Date/Time: Sat, 30 Nov 2024 16:20:47 +0000
Sierra Chart 2053 update
View Count: 320
[2022-11-15 14:27:38] |
DoubleM - Posts: 6 |
downloaded the zip installer but lost all of my custom charts. There was a problem with the Denali data feed. I then updated Sierra Chart as per the directions. The updates seems to have corrupted my chart files and the update keeps stating failed to open the file. Is this a bug you are not aware? |
[2022-11-15 14:34:46] |
Sierra_Chart Engineering - Posts: 17272 |
Please confirm you have the correct telephone number here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Then we can use remote assistance and look into this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-15 15:00:34] |
Please let us know when we can give you a call to help with this.
