Date/Time: Sat, 30 Nov 2024 16:31:45 +0000
Confirming steps for multiple accounts with Denali
View Count: 531
[2022-11-15 03:56:06]
Ayal416 - Posts: 6
I have service package 11 with the Denali futures data feed.
I recently signed up for Apex Trading - a futures prop frim which uses Rithmic (terrible).
I also have an IB account with NO data subscriptions at all.
I would like to use the Sierra/Denali data feed and market depth that I have now and trade the various accounts using Sierra.
Reading Using Multiple Data and Trading Services at the Same Time
it says "Although it is important to be aware that in the case of when using one of the Real-Time Exchange Data Feeds Available from Sierra Chart, this data feed can be used on its own and is also integrated with all Trading services. Therefore, there is no need to use multiple copies of Sierra Chart running on your system. You can use just one single copy. For additional information about this, refer to Integration with Trading Services."
Reading the related page, it seems that I do not need to install a separate copy of Sierra for IB and Apex/Rithmic.
Is that corrected?
Please confirm the steps I need to take to
- Trade the Apex account using Sierra
- Trade my IB account
Thanks in advance.
[2022-11-15 11:57:32]
Sierra_Chart Engineering - Posts: 17272
We definitely would recommend two separate installations of Sierra Chart. One for Interactive Brokers and the other for "Apex Trading - a futures prop", if you plan to use both of them even if at different times.
Here are the instructions for that:
The Denali Data Feed can be used with both. No problem.. Documentation:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
