Date/Time: Sat, 30 Nov 2024 16:38:07 +0000
Data issue - Mapping issue - No (M)
View Count: 310
[2022-11-15 02:20:34]
User804288 - Posts: 2
Hi, I upgraded from 5 to 11 and followed the instruction on data connection but I am not getting an (M) at the end... download is failing, you suggested it might be a mapping issue.
..Edit, Translate symbols to current Service isn't working.
I was using CQG before.
Thank you.
[2022-11-15 08:04:53]
Sierra_Chart Engineering - Posts: 17272
You first need to complete the agreements here:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements
And then activate the exchanges:
