Date/Time: Sat, 30 Nov 2024 16:40:49 +0000
Sierra Chart is lagging and refreshes every few seconds
View Count: 314
[2022-11-14 14:04:17] |
TekinTrading - Posts: 8 |
Hello My Sierra Chart is so laggy. I have to restart the Plattform so many times, until it finally works (sometimes). It is not because of my Data Feed. I want directly help from the support and no references to any old pages, thanks |
[2022-11-14 18:59:17] |
The only thing we can do is point you to the following: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-14 19:58:40] |
Sierra_Chart Engineering - Posts: 17272 |
That is a very long page. Sorry about that. There is a process to go through to resolve this. Get started with this subsection: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart Section 3.48. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-14 19:58:57
