Date/Time: Sat, 30 Nov 2024 16:41:45 +0000
Unable to load historical intraday data
View Count: 437
[2022-11-14 07:51:58]
gambleditall - Posts: 16
I recently updated Sierra Chart to the latest version. I am currently on Sierra Chart Package 3 which includes the historical data service. I have previously used these settings successfully to download historical 1-min OHLC data all the way from 2008. However, it does not seem to be working anymore.
The only settings I have changed from default are:
Data/Trade Service Settings
Intraday Download Interval for Non-Real-time Symbols (min): 1
Chart Settings > Symbol
Continuous Contract: Continuous Futures Contract - Date Rule Rollover, Back Adjusted
I have attached the log, on which the last line is 'No download requests in the queue to start downloads for.'
Chart Settings > Data Limiting
Load Data Limiting Method: Use Number Of Days To Load
Data To Load for Intraday Chart Data Type: 182
Chart Settings > Bar Period
Graph Draw Type: Candlestick Bars
Chart Settings > Session Times
Session Start Time: 00:00:00
Session End Time: 23:59:59
Use Evening Session: No
I have already tried the following to no avail:
Disconnecting and reconnecting to the data feed.
Edit > Delete All Data And Download
The symbol I am trying to download data for is NQZ2022
Date Time Of Last Edit: 2022-11-14 07:53:20
Private File
[2022-11-14 10:13:15]
Sierra_Chart Engineering - Posts: 17272
Select Edit >> Cancel Intraday Data Downloads.
And then follow the procedure here:
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
[2022-11-15 05:28:08]
I have followed those instructions and attached is the log.
EDIT:
I think I have found the issue. It seems to be that it is rendering issue rather than a data issue. After the data is downloaded (as shown in the log), if I click Edit > Cancel All Downloads, it renders the chart. If I do not do this, it just shows the 'Downloading Continuous Contract Data' and a blank chart.
Date Time Of Last Edit: 2022-11-15 05:51:54
Private File
[2022-11-15 11:59:08]
No, that is not the issue. There is just a long time to download the data. We recommend following the instructions here to reduce the amount of time to download the data:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance
