Date/Time: Sat, 30 Nov 2024 16:27:41 +0000
Updating global symbol setting using IB data
View Count: 500
[2022-11-14 02:33:27] |
paul gierer - Posts: 18 |
I am receiving Interactivebrokers futures-their data continues to come in with original symbols so for the next step: Changing Symbols of a Chart what symbol do I use for example ( sp500 futures) for the chart? There is no charting using the original symbol so I am totally confused
[2022-11-14 05:46:18] |
User584084 - Posts: 262 |
IB is changing their futures symbols. Replace GLOBEX with CME in the futures symbol. So the ES-202212-GLOBEX symbol is now ES-202212-CME. NQ-2022212-GLOBEX is now NQ-202212-CME. EUR-202212-GLOBEX is now EUR-202212-CME, etc.
[2022-11-14 10:08:05] |
Sierra_Chart Engineering - Posts: 17272 |
To find out what symbols to use go to File >> Find Symbol >> Futures and then find what is the current symbol to use for a particular futures market. And follow the instructions here to change the symbol of the chart: Changing the Symbol of a Chart: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-14 18:49:41] |
Also refer to the following: *Important Notice*: Interactive Brokers Symbol Changes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-14 20:54:01] |
The futures with new symbols for intraday ES/NQ charts download less than 1 month of data is that correct?
[2022-11-14 22:15:45] |
Yes. IB only provides 30 days of intraday data.
[2022-11-14 23:27:47] |
Complete the agreements and activate the exchanges here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME Then you will very fast , complete and years of historical data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-14 23:28:22
