Date/Time: Sat, 30 Nov 2024 16:35:25 +0000
AV-BV-AP
View Count: 468
[2022-11-14 00:23:28] |
User179004 - Posts: 1 |
IS POSSIBLE TO OUTPUT AN ASK OR BID VOLUME AT PRISE IN A SPREADSEET?
[2022-11-14 18:42:48] |
It is possible to output a specific price level ask or bid volume by using the Spreadsheet Formula study. This study uses the Alert syntax, so you can use the AVAP() and BVAP() functions from the alerts and specify a particular price level for which you want the data. Refer to the information here: Study/Chart Alerts And Scanning: Special Functions What you will get in your Spreadsheet is the Bid or Ask size at that price for each bar. There is not a way to get the data for each level at each bar. To do this, you would need to create a custom study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-14 18:46:17
