Date/Time: Sat, 30 Nov 2024 16:42:27 +0000
(solved) the market depth historical graph
View Count: 450
[2022-11-13 13:19:00] |
d9e5c763 - Posts: 108 |
these two screenshots are es and nq 1 min charts. the depth data has been completely deleted and re-downloaded. can see that there are "yellow stripes" below the bid price, and the nq chart lasts longer. what does this mean? can briefly explain?
screenshot-20221113-210900.jpg / V - Attached On 2022-11-13 13:17:27 UTC - Size: 109.82 KB - 110 views screenshot-20221113-210918.jpg / V - Attached On 2022-11-13 13:17:32 UTC - Size: 65.84 KB - 110 views |
[2022-11-14 17:56:40] |
In the NQ chart it looks like you have the option for Extend Last Known Depth set to Yes. Refer to the following for this Input: Market Depth Historical Graph: Extend Last Known Depth Which also means that the actual depth for that time period is not present. Therefore, you may want to force a download of the missing depth data in that area. Refer to the following: Market Depth Historical Graph: Downloading Of Historical Market Depth Data We can not say why that data did not fill in if you have already done a download, but try again and see what happens. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
