Date/Time: Sat, 23 Nov 2024 15:23:46 +0000
[User Discussion] - Routing Option for Interactive Brokers
View Count: 769
[2022-11-11 23:39:30]
User396 - Posts: 55
Is there anyway I can specify routing option for Interactive Brokers orders? This is especially needed for limit orders as there is a rebate involved. Market order it doesn't matter much though.
[2022-11-12 13:31:47]
Sierra_Chart Engineering - Posts: 17149
This is not clear for us. All settings for Interactive Brokers can be found in Global Settings >> Data/Trade Service Settings>> Main Settings . If what you are looking for is not there, then it is not available.
Date Time Of Last Edit: 2022-11-12 13:32:05
[2022-11-13 05:08:47]
User900285 - Posts: 94
Yes this is possible when you are specifying the Trade only symbol.
Let's say you are trading the symbol AMD with Interactive Brokers and using the market data from Sierra Chart from their Nasdaq feed.
The Symbol would be set to AMD-NQTV and the Interactive Brokers trade symbol would normally be this. AMD-STK-SMART-USD.
To direct rout an order you need to specify the sub exchange like this. AMD-STK-ISLAND-USD. Do not include SMART.
That will direct rout your order to ISLAND.
That will bypass the IBKR SMART routing system. When you do that for the first time you will get an error hit the message log and you will need to check a box in the TWS API Precautionary settings. It is the last setting 'Bypass Redirect Order Warning for Stock API Orders'.
[2022-11-13 08:11:54]
Thank you for this. We did not realize this is what they were asking for.
Date Time Of Last Edit: 2022-11-13 08:12:04
[2024-08-09 20:50:31]
User396 - Posts: 55
This is an old post, but I would like to follow up and ask if you know how to specify "SMART Maximize Rebate" while placing the order.
Would this be AMD-STK-MaxRebate-USD?
